New to the site here and I searched for a problem like mine and couldn't find it. But I want to say this looks like a great site. Thanks for having me.
I picked up a 96 Foreman 400 all stock about 2 months ago. When I got it, it ran great. But after my 3 ride on it that changed. I was on it about 3 hours, just trail riding. On the way back I noticed that the engine whined a little. Just a little higher pitch then normal. I parked it in the garage. A couple of days later I had the time to look at. I wouldn't even idle. I had to have the choke fully on and even then it ran rough. I pulled the carb and cleaned it till it looked new, well almost new. Changed out the spark plug. Now it wants to idle but misses, if the choke is on it will run pretty smooth, little back fire on the return to idle speed, then it starts missing again. Is there a timing adjustment on these?
I also have another issue with it too. But I haven't had a chance to test anything on it till I get it running smooth again. There is a good amount of drag on it, like the brakes are dragging. Might just be the bearing are shot, cause it doesn't seem like the previous owner maintained it as well as he said he did. But I will work on that issue later.
Any ideas or thoughts would be great. And again thanks for having me here.
